Timing Chain Question
I've gone over the threads recently and I don't recall them mentioning anything about the engine/cam timing marks; they only talked about how to install the tensioners without changing the cams/chains relative positions.
DAN L (04-24-2015)
Reason for doing that way is so you don't have to disassemble the front of the engine to install all the clamps required to set the timing. I found some details to manufacture all the parts to do it but there were quite a few and easiest way is in the DIY.
No timing marks that I know of, just a lot of fixtures and clamps. But if you were going to do that you might want to do the mains too.
DAN L (04-24-2015)
