Timing Chain Replacement Tools
Old 05-19-2014, 09:12 PM
jimmiejag's Avatar
Default Timing Chain Replacement Tools
I plan to replace the tensioners, guides and timing chains on my 1999 XK8 and found these tools on Amazon:
Robot Check Robot Check
Does anyone have any experience with these tool set or this brand? The set looks like it is complete for a complete chain replacement.
Any opinions of this set from anyone who has used them?
Thanks,
Jim
Old 05-19-2014, 09:13 PM
jonscot's Avatar
I ordered this same set on weds - should be here soon. Happy to let you know if they do the job.
preuss2 (05-19-2014)
Old 05-19-2014, 09:25 PM
test point's Avatar
Received 1,111 Likes on 932 Posts
That set would appear to be very adequate in doing one side at a time.
[edit] sorry, it has two cam lock down bars.
preuss2 (05-21-2014)
Old 05-19-2014, 09:44 PM
Jdub's Avatar
ud
I highly recommend one that has a cam locker for both sides. If one of the cam slips at all you can kiss your motor goodbye.
Old 05-19-2014, 09:58 PM
giandanielxk8's Avatar
Received 1,436 Likes on 769 Posts
Or you could do the zip tie method...
Old 05-19-2014, 10:02 PM
dieseldoc's Avatar
I picked up that set on ebay for $186.00 free shipping, it worked real good definitely up to the task. I've been wrenching for a living for 33 years and consider it a good addition to the tool box.
preuss2 (05-20-2014)
Old 05-19-2014, 10:35 PM
stevepaa's Avatar
I used the same and did mine during winter
Old 05-19-2014, 10:43 PM
avt007's Avatar
Mine had a different brand name, but were the same set, worked great.
IF you want more detailed pictures, check out my thread, here-https://www.jaguarforums.com/forum/x...-review-99234/
Old 05-20-2014, 01:41 AM
Jacob67's Avatar
This kit from Laser Tools might be an alternative.
http://lasertools.co.uk/items/pdf/Pr...structions.pdf
Old 05-20-2014, 07:29 PM
jimmiejag's Avatar
Default Ordered One
As the OP of this thread, I appreciate the information posted in these replies.
Based on the recommendations and a good price (including free shipping,) I ordered the tool set.
I'll follow-up on this forum with an evaluation after I have had a chance to use the set.
Thanks.
Norri (05-21-2014)
Old 05-20-2014, 09:54 PM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
I have a loaner on my page if you need it.
Old 05-27-2014, 06:39 PM
jimmiejag's Avatar
I am the OP of this thread and am following-up on the eBay timing chain replacement tool set. The set arrived via UPS toady and while I haven't had a chance to use them yet, they appear to be well-made and are packaged in a nice blow molded case.
I won't be tackling the chain/tensioners/etc replacement for a while, but will post my experience with the tools after I've used them.
Thanks for the replies.
Gus (05-27-2014)
lobsterD90
11-12-2022 09:51 PM
xjrjag
10-27-2021 11:48 PM
Bcrary3
09-12-2015 08:43 AM
David Mason
09-03-2015 03:17 AM
Bcrary3
08-31-2015 11:29 AM
Quick Reply: Timing Chain Replacement Tools
