Andy,
Great blog! My fixer ($800) is a 98 XJ8. Body and interior looks like a 40k car, but the engine broke at 150k. Original owner must have had bad hearing, lol. Anyway, it was a busted secondary chain on passenger side. Sound familiar? My leakdowns were not below "moderate" so I refrained pulling heads. My new chains are very tight...even without the wedges. I'm going with "tight" since they will only get looser.
Can I replace the upper timing chain tensioners myself? Or is there a lot I can screw up? I did rebuild a few VW Beetle engines before.
BTW: I live in Minnesota, so I only get to enjoy my XK8 for another four weeks this year before it goes into hibernation. I will not drive it in salty snow slush that eats metal. So I have several months to figure out the timing chain tensioners.
I wouldn't try it without at least dropping your oil pan for examination. You might find the plastic guide or original tensioner parts in the bottom. While there, remove the oil intake and shake it. I found pieces in mine. All my guides were shot, but I bought a fixer, not running, so expected the worst.
May I ask what that assortment of parts cost? I probably should do this on mine. Thanks
Figure around $1,000 total for tools (required!) and parts.
Chains/tensioners/guides are $300, gaskets another couple hundred. A local Jag mechanic quoted $2,500.
I replaced the primary and secondary timing chains, guides, and tensioners last year. I tried my best to document everything so that anyone considering tackling this can see what they're up against. I think I covered all of the challenges and you can see how I solved them before you even start. You don't need to go down the dead ends like I did.
See below. https://www.jaguarforums.com/forum/x...ioners-214569/
Hi,
I live in Singapore and drive an early 1997 XK8 4.0 Convertible, with about 140,000 km on it.
In 2012, I had my timing chain tensioners changed by the main Jaguar dealer here, when I first got the car, and it had just 40,000 km on it at that point.
Two weeks ago, in the process of replacing my cylinder head gasket, my new mechanic discovered cracks on the timing chain guides.
We decided to do a replacement with a new timing chain kit to be bought, and the old bits replaced.
Upon delivery from SNG Barratt in the UK, we noticed that were size differences between the old timing chain guides and the ones we just received.
Has there been any modification to the dimensions of the timing chain guides as part of the product improvement?
I have attached images of the old and the new timing chain guides, with the new shiny ones placed right next to the old slightly cracked ones.
The new guides are slightly longer in length, and they are also narrower in width than the original pairs.
Do they look like the correct parts, or did we receive the wrong set of guides by mistake?
Appreciate some advice. The old guides are on the right, and the new shiny guides are on the left, for each pair. The chain appears tight in the new guide. The old parts and their replacements which were part of the Timing Chain Kit.
Those aluminum backed guides are for the SILENT-RUNNING 'Morse' style primary chains. I just buy the original Jaguar wide guides for the roller chains on the early engines and toss the thin ones from the various kits into a box.
Probably go into the aluminum recycling bin someday.
Thank you for that quick reply. You are right. The guides and blades that SNG Barratt sent me as part of the replacement kit were the wrong ones (meant for the post 2002 XK8).
I've alerted them, and hopefully they will send me the replacements soon.
Many thanks again!
Better than 2 quotes here. One was 3,200. Second was 4,000. Plan
was to do just the uppers then I see read the stories and see the pictures...........
DIY is obviously cheaper (maybe I should be looking around for jack stands and dusting off my tool box). Local's quote 2,000 to do just the uppers. Quote included new cam covers ($1,000) to reduce chance of leaks? Am guessing it's easy for him to install since bolts come preinstalled in covers. New gaskets and old covers should be fine. Now we're at 1,000 to do the 2 uppers. Drove the car this morning. No noise but it's time to do at least the uppers.
Remove $38.79
$38.79 Price Quantity Total Tap to expand
PREFERRED COMPONENTS INC T66231InfoC Right Upper; Secondary Chain Tensioner
{Click Info Button for Alternate/OEM Part Numbers}
(Only 1 Remaining)
Remove $36.99
$36.99 Price Quantity Total Engine : Valve Cover Gasket
Tap to expand
FEL-PRO VS50724RInfoB PermaDry molded rubber Gaskets. incl.; Includes Spark Plug Tube Seals; Valve Cover Grommets Included
{#VS50397} [[url=https://www.rockauto.com/lang/en/answersTab2.html#closeout]Wholesaler Closeout -- 30 Day Warranty] ($13.89)
Remove $5.78
$11.56 Price Quantity Total Subtotal $101.23
Address Information Email Address
Order Number OR Zip/Postal Code
Remember Me (Optional) Full Name Address
City
State
AAAEAKALAPARAZCACOCTDCDEFLGAHIIAIDILINKSKYLAMAMDME MIMNMOMSMTNCNDNENHNJNMNVNYOHOKORPARISCSDTNTXUTVAVT WAWIWVWY Zip/Postal Code
Country
United StatesAlbaniaAlgeriaAmerican SamoaAndorraAngolaAnguillaAntigua and BarbudaArgentinaArmeniaArubaAustraliaAustriaAzerba ijanAzores (Portugal)BahamasBahrainBangladeshBarbadosBelarusB elgiumBelizeBeninBermudaBhutanBoliviaBosnia-HerzegovinaBotswanaBrazilBritish Virgin IslandsBrunei DarussalamBulgariaBurkina FasoCambodiaCameroonCanadaCanary Islands (Spain)Cape VerdeCaribbean Netherlands (BES islands)Cayman IslandsChileChinaColombiaCongo (Republic of)Cook IslandsCosta RicaCôte d'IvoireCroatiaCuraçaoCyprusCzech RepublicDenmarkDjiboutiDominicaDominican RepublicEcuadorEgyptEl SalvadorEquatorial GuineaEstoniaEthiopiaFaroe IslandsFederated States of MicronesiaFijiFinlandFranceFrench GuianaFrench PolynesiaGabonGambiaGeorgia, Republic ofGermanyGhanaGibraltarGreeceGreenlandGrenadaGrena dines (St. Vincent and the Grenadines)Guadeloupe / Saint BarthelemyGuamGuatemalaGuernseyGuineaGuinea-BissauGuyanaHaitiHondurasHong KongHungaryIcelandIndiaIndonesiaIrelandIsraelItaly JamaicaJapanJerseyJordanKazakhstanKenyaKorea, Republic of (South Korea)KosovoKuwaitKyrgyzstanLaosLatviaLebanonLesot hoLibyaLiechtensteinLithuaniaLuxembourgMacaoMacedo nia, Republic ofMadagascarMalaysiaMaldivesMaliMaltaMarshall IslandsMartiniqueMauritaniaMauritiusMexicoMoldovaM onaco (France)MongoliaMontenegroMontserratMoroccoMozambi queMyanmarNamibiaNepalNetherlandsNetherlands AntillesNew CaledoniaNew ZealandNicaraguaNigeriaNorthern Mariana IslandsNorwayOmanPakistanPalauPanamaPapua New GuineaParaguayPeruPhilippinesPolandPortugalPuerto RicoQatarReunionRomaniaRussiaRwandaSaint Kitts (St. Christopher and Nevis)Saint MartinSaint Pierre and MiquelonSamoaSan MarinoSaudi ArabiaSenegalSerbia, Republic ofSeychellesSierra LeoneSingaporeSint MaartenSlovak RepublicSloveniaSouth AfricaSpainSri LankaSt. LuciaSurinameSwazilandSwedenSwitzerlandTaiwanTanza niaThailandTogoTongaTrinidad and TobagoTunisiaTurkeyTurkmenistanTurks and Caicos IslandsUgandaUkraineUnited Arab EmiratesUnited KingdomUruguayUzbekistanVanuatuVaticanVenezuelaVie tnamVirgin IslandsWake IslandWallis and Futuna IslandsZambia Phone
Email Shipping Address
Billing Address
Same as Shipping Address
Shipping Enter Zip/Postal Code above to calculate shipping.
Tax, Total, & Payment Parts Cost $101.23 $101.23 Please Select Payment Method
Split Payment?
All sales subject to our Return and Warranty policies.
How Did You Hear About Us?
Place Order Email this cart to a friend (or yourself)
Available Carts 2021-05-06 04:32:52
here is a part order for what you need to do the secondary tensioners. You can get everything for a little over $100. As I mentioned before that you are local and I have the tools needed.If you want I can loan them to you or possibly assistif I have time. You should stop talking about changing them and do it or you can change your name from CaJag to CaPaperweight. If you have the origional tensioners there is a high probability that they are cracked. You don't need new cam covers unless they are cracked. If you have a bad one I have extra ones. It takes a little more time to install new gaskets compared to my'66 Mustang, but at $1000 a set I will do them all day long and with lumber prices now I might be able to afford a couple of sheets of plywood.The ball is in your court. Let me know if you need my assistance.
BobRoy thanks for taking the time to put together the info and also for your generous offer. You're right. Probably time to change my name to CA Lightweight. It's a familiar story in here but I've put way more time and work into this car than planned. Bought a fixer Jag w/ no history. Never again. Besides the tensioners issue, the top just stopped going up (low fluid? valve?) and found a trans leak. Get into that one and it's time to change the fluid and filter. It's a Jag but am guessing this car will have more issues than normal because of the lack of maintenance. My big problem is not having enough time. Upside here? I've driven out in the country in a vintage XK with the top down. Thanks again.
Whatever you do, don't get discouraged. It will seem that everytime you fix one problem another rears its ugly head. These are beautiful cars and fun to drive. My wife and I took the 2000 xk8 through Napa a few weeks ago. It was the first time I had it out after replacing the engine and upgrading the front suspension that took me over a year. There is nothing better than crusin through wine country with the top down and letting both of my hairs blow in the wind.
I get the feeling from your post that you are exited about your car and you are enjoying the forum. If it wasn't for this forum I proably would of given up on my first Jaguar. No only did I get the information to help me get my car back on the road I got hooked to where I have 8 or 9 Jags. I think I have made several friends over the years, I hope they like me because I like most of them.
Tomorrow I will be at my shop, a warehouse with all of my stuff, cleaning up. If you want to stop by if you have time we can take a look at your top. I have the proper hydraulic fluid if it needs to be topped off. If you want we can pull a cam cover off to check your secondary tensioners. We can see if the are a time bomb with a short fuse. I also have the Icarsoft scanner for Jaguar. It will give you alot move info than an OBII scanner. I willing to give you an hour of my time to check out your car. If you stay longer than an hour you will have to help me clean up. 😁 If tomorrow doesn't work we can make it another time if you want.
Whatever you decide I wish the best for you.
You nailed it. I really like the car and the forum has been great. Guess I'm hooked. I've been going on and on about the tensioners. Wondered if you could get me banned from the forum
Yeah the top stop was kind of discouraging. Checked the oil level on the pump. Within range. Valve seems fully closed. No obvious leaks altho the lines feel slightly greasy. Latch doesn't seem to be unlocking.
The trans leak is a can of worms.
Tomorrow is good. I'll PM you to get info and to see if I'm bringing wine or beer.
Bob, just wanted to say it was great talking with you. Thanks for answering my questions. The show and tell really helped. The broken secondary tensioner is sitting on my desk as a reminder. Happy to know "CA Paperweight" comment meant the car (not me). Glad to hear it's possible to drive a Jag cross county. My goal is Olympia WA one of these days
