Timing Chain Tensioners
I have spent most of this afternoon going through the posts for XK8 and I am now getting concerned about my timing chain tensioners!
I have a 2001 XK8 with 55,000 miles, on a cold start I have no "rattle" from the front end and my local Jaguar mechanic says the engine sounds fine and I do not need to spend $1800 on this job to replace them. Is he right?? Will I hear when these tensioners need replacing? do I wait until 60K miles? do some engines never need the tensioners replacing? What would you suggest bearing in mind $1800 is a lot of money when you are retires and on a fixed pension. Thanks for your help, regards, David
![Wink](https://www.jaguarforums.com/forum/images/icons/icon12.gif)
Doug
Try this URL:
https://www.jaguarforums.com/forum/s...ight=tensioner
This is the FAQ thread with the string "tensioner" highlighted.
Try this link to:
http://www.jag-lovers.org/cjw/#0104a
I am not mechanically inclined but the FAQ section and its links has kept me informed and educated about the car.
Good luck!
Try this link to:
Good luck!
The secondary tensioners are easy. I did mine with a $10 set of ACE Hardware sockets and a few other tools. The instruction links cover everything you need to know. The satisfaction of doing it yourself is more than worth the effort. I attended a Jaguar club function and an acquaintance introduced me as testpoint . . . he did his own tensioners.
Here is another link from another source covering the tensioners.
http://www.jagservice.net/jaguar_v8_...tensioners.htm
I did mine in a half of a day.Have fun!
Hey Dave,
I hope I did not offend by presuming that (1)you were an older guy and (2)this would be too hard to tackle.
I guess I was projecting my own shortcomings. I am not all that old yet and would love to do this type of work (like I used to in my younger days). But I have found over the last few years that bending over an engine compartment for even a short time results in my back being out of whack for days afterward.
If you do tackle the project be sure to take a bunch of photos and post your experiences.
Thanks,
Doug
Thanks,
Doug
Uh... not in this case. The tensioners can fail suddenly without warning. If the tensioner fails the valves will get out of sync with the pistons. The pistons slam into the valves causing them to break off, gouge the cylinder walls, and possibly even puncture the pistons. Then your car will need a whole new engine. Failure to replace the tensioners could end up costing $5000 or more.
![Red face](https://www.jaguarforums.com/forum/images/icons/icon11.gif)
RoyLittle0
05-25-2023 02:38 AM
