Tire pressures
Your 2007 XKR should be the later aluminium bodied X150 and not the 1996 - 2006 steel bodied X100.
However, the same advice applies to tyre pressures. Follow the Manufacturer Recommended on the label - NOT the Maximum Permitted on the sidewall:
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/292x326/tire_pressures_85d9fd3aca0bd0a5cc665b9a038a044534a2b461.jpg)
Received 1,686 Likes
monitor tire wear weekly or monthly, depending on how much you drive. I put the Jaguar recommended tire pressure in my tires, and it was way too much. Overinflation is easy to spot as it causes the center of the tire tread to wear out first. On my new tires I dropped the pressure down 4 psi, and the new tires appear to be wearing normally.
Z
Z
