Tire question bbs
What Billy said. I had my tires mounted by an independent jaguar specialist that I trust. A regular tire shop could probably do it, but I was afraid that they'd forget to return my inflation adapters. I figured better safe than sorry.
You can get the extra valves and caps from either Dave Roche @ DCR, or order them directly online from PW motorsport here: https://www.pwmotorsport.com/pr,130,...bs-valves.html
You can also get extra adapters, bolts,etc from either as well. I had one of the caps fly off a while back, so I can attest to the value of having spares.
Thank you for that. Really useful and hard to find.
Funnily enough I just changed the tires on my car. 2003 Convertible. 20" rims. Montreal wheels. Have a read, you might find useful information. Click Me To Read
In order to have a closer look at my rotors, I need to remove a 20" BBS wheel (Detroit wheel). Do I need to remove the center cap in order to remove the wheel. In other words, is there a nut behind this cap that needs to be unscrewed to remove the wheel or just the 5 nuts like any other wheels?
Thank you and sorry for my lack of knowledge.
Great thank you.
I'm going to change my rotors. Question, are there nuts and/or bolts that need replacement? Like calipers mounts, hub's, wheel's etc. in a few words, anything related to changing pads and rotors? I've read somewhere some are thread lockers and need replacement after a while. And also where to find these?
Thanks a lot.
Thanks a lot.
Alexander...…..
Please, with your limited Knowledge, DO NOT attempt this job yourself! Please take the Car to an experienced Brake Mechanic, who has the proper Tools and Machinery to do a proper job on your Brembo's.....This is not a job for armature Mechanics, and you don't have the knowledge needed to do the job properly. The last thing you want to do is hit the Brakes and all Hell brakes lose!....This could be deadly to you or someone else! .
From the looks of them in your Photos, I would just leave them be, as they really don't need changing right now but that's up to you....This is going to cost you some big $Bucks!
Billy Clyde
Billy Clyde
#28
Alexander...…..
Billy Clyde
Billy Clyde
Thanks.
#30
BCP
#31
Thank you for being a friend and looking out for me and for others.
Miami XKR
01-30-2011 01:25 PM
