tire size
Old 09-08-2014 | 05:59 AM
mark campbell's Avatar
Default tire size
i need to get a set of tires-----is there a problem running the same size on all 4 corners--i have standard 2002 xkr rims ----- thanks
Old 09-08-2014 | 07:23 AM
graham11's Avatar
Default tyres
hi there,i have 255/40/18s all round never had eny probs with my bridgestone Potenza runflats but not sure if you can go eny wider than that on the front ,other members may give you a better answer.
Old 09-08-2014 | 07:38 AM
steeevo's Avatar
Same here, im running potenza's all round with no problems, it says under the centre console what size they should be and mine says 17 245 50 so thats what i have got all round
Old 09-08-2014 | 10:25 AM
Paul Pavlik's Avatar
The XKR standard 18" Rims would be 9" wide in the Rear and take a 255/45 Tire.
The 18" Front Rims would be 8" wide and take a 245/45 Tire.
Old 09-08-2014 | 10:54 AM
Torrid's Avatar
You could technically run the same size front and rear, but why? With the staggered width wheels you wouldn't be able to rotate them.
Old 09-08-2014 | 11:33 AM
graham11's Avatar
Default tyres
I agree with that but the extra width does look much better plus that bit extra rubber on the road is a bonus,i would love to no just how wide we can go on the 18s at the front.
Old 09-08-2014 | 12:59 PM
Torrid's Avatar
On an 8" wheel 235-245 is ideal, 255 is pushing it but would work. You could go up to a 265 on the 9" rears.
Old 09-10-2014 | 07:23 PM
petes76's Avatar
I'm running 255/35 x20 x 9.5 wide D'Vinci Povatti rims all round on my 2000 XKR convertible and the fronts foul the fender , so I'm getting the front rims replaced with 8.5" wide, and run 235/35 x20 on the front. Ive manage to source matching fronts at 8.5" wide, so I'll have a spare set of rears.
Old 09-11-2014 | 01:06 AM
Krajcok's Avatar
What is their offset? You could use 9.5 in rims in the front but the offset can not be lower than 20mm.
petes76 (09-12-2014)
Old 09-12-2014 | 12:53 AM
petes76's Avatar
Not sure of the offsset, but I need to get the rims off and atake a look. It could just be the springs or even worn out shocks, as the front of the car does slope down.
MrWest
12-01-2015 10:18 PM
TimelessR
10-22-2015 03:00 AM
smith356
10-07-2015 07:41 PM
Gerard Radimaker
09-13-2015 11:33 AM
Quick Reply: tire size
