To 'Tonneau' or not to 'Tonneau'
As the weather in S.W. Florida can change rather rapidly, I sometimes lower my top and do not cover with the tonneau unless I am fairly certain I will be out without needing the top back up soon. How many other 'Vert' owners drive without the tonneau? I know the inner lining flaps in the wind a good bit, and this is not good for long term wear, but other problems?
DavidYau (08-01-2021)
I do not normally put the tonneau cover on as I prefer to drive with the top down but almost always put it back up when parking while shopping. I did wedge a length of 2" (51mm) diameter pool noodle down into the lining to keep it from fluttering in the wind. Works great, not normally noticeable, and no damage if you attempt to put the top up without remembering to see if the tonneau cover is on or not (ask me how I know...). I pulled it up just a little for the attached photo. The noodle automatically drops into the back seat when the top starts moving. Note: Not my tip, but I can't find the original submitter to give credit to.
I almost never use mine unless trying to look extra fancy or taking a long drive at freeway speeds with the top down. As someone said. I usually put top up each time I park (btw, I love my JagWranger remote control top module). So it would be a lot of fussing about to use the boot cover. In fact, I keep it in my garage instead of the car most if the time. I just vacuum my headliner fairly often and don’t worry about it.
Johnken (07-31-2021)
