Top now not working with manual latch
Hi Wojo,
Just found your reply. Thanks. I have not done much more with the top since my last post. But I have always suspected the yellow solenoid since the fuse does not blow if I unplug the yellow one. I must admit I don't quite understand the operation of the solenoid in this application, but have wondered if the solenoid could be jamming the pump or have a short of its own. Do you know if removing the solenoid for inspection is wise?
You have 2 relays for the pump motor up and down controlled by the security module. When it sends a signal to the relays that are being protected by a 5 amp fuse it sends power to the pump to operate and it is protected by a 40amp fuse. The latch and main control valve is controlled by the security module.
This is a link to wiring diagram for 2003 and fig 5.2 is what you want to look at.
Link http://www.jagrepair.com/images/Auto.../jagxk2003.pdf
Stamford (10-16-2014)
BrentGardner
28
04-26-2024 03:08 AM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
