Top now not working with manual latch
Old 10-14-2014, 09:05 PM
Stamford's Avatar
Hi Wojo,
Just found your reply. Thanks. I have not done much more with the top since my last post. But I have always suspected the yellow solenoid since the fuse does not blow if I unplug the yellow one. I must admit I don't quite understand the operation of the solenoid in this application, but have wondered if the solenoid could be jamming the pump or have a short of its own. Do you know if removing the solenoid for inspection is wise?
Old 10-15-2014, 08:40 AM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
You have 2 relays for the pump motor up and down controlled by the security module. When it sends a signal to the relays that are being protected by a 5 amp fuse it sends power to the pump to operate and it is protected by a 40amp fuse. The latch and main control valve is controlled by the security module.
This is a link to wiring diagram for 2003 and fig 5.2 is what you want to look at.
Link http://www.jagrepair.com/images/Auto.../jagxk2003.pdf
Stamford (10-16-2014)
Old 10-15-2014, 10:39 AM
cagneykitty's Avatar
by disconnecting the battery to reset the computer will this do any harm to my jagxk8
Old 10-15-2014, 01:43 PM
Gus's Avatar
Gus
Gus is offline
It should not if done properly.
Old 10-16-2014, 09:24 AM
Stamford's Avatar
Thanks, although the schematic is Fig. 15.2.
BrentGardner
28
04-26-2024 03:08 AM
johnnie ryall
10-19-2015 09:44 PM
JagCad
09-05-2015 07:23 PM
anthem
08-31-2015 02:01 PM
Jandreu
08-29-2015 07:31 PM
Quick Reply: Top now not working with manual latch
