top operation
You need to turn it quite hard past the stop and hold it, (it is spring loaded). Are you sure you are turning it hard enough?
Received 4,341 Likes
One of the advantages of the Remote Top that I sell is it is two touches on the remote and then you do not need to hold the buttons.
magnum454 (07-01-2014)
It will draw about 0.20% (one fifth of 1%) of the battery charge for each top cycle. That is not enough to have any meaningful effect on the battery life. The unit itself draws virtually zero standby power (a few millionths of an amp).
There are now hundreds in use and no reported issues once properly installed.
aholbro1
08-05-2021 05:02 AM
