Top reluctant to open
Hello all. It's been a while since I've visited the forum, happy to say that there haven't been any problems with my XK8 for some time until today.
When I try to put the top down, I can hear the hydraulic motor running, however the top will not begin to come down unless I apply some upward pressure by hand.
I'm not sure if this indicates a problem with the latch not releasing fully, or if the pressure is too low to pull the top down. I can put the top up, and it will latch, without any problem.
I checked the fluid reservoir and the fluid level is right in the middle of the fill lines, so it's not a matter of low fluid.
Any ideas what might be causing this problem?
If you have a '99 or newer follow these instructions:
The top will 'reset' if you manually lower it. The owners manual shows you how, or see Gus' instructions here: JagRepair.com - Jaguar Repair Information Resource.
While it is down, try lubricating all the joints and latch with some light oil. Also. re-inspect the fluid level and make sure you do not have a developing leak. When you return to automatic mode, make sure the petcock on the pump is firmly clockwise.
If you have an older model, you may need to flush the fluid and reprlace it with Pentosin CHF-11S.
The following 2 users liked this post by WhiteXKR:
OhioXK (08-03-2015),
test point (07-30-2015)
aholbro1
08-05-2021 05:02 AM
