Top Wont Go Up Down, Rear Windows???
Received 2,190 Likes
Chaps
I did disconnect the ground terminal while I worked on the car.
I now have no response from the top, either to raise or lower. It appears to be stuck in an almost closed position. I tried opening the pump valve once again to manually ope, but its like the top is not letting the hyd fluid return to the reservouir. Its just locked. Is there a spot to add additional fluid if low? Is there a electric relay that I might have an issue with?
Did Brutal's suggestion work?
If it does not, you will need to manually latch the top to reset the sequence. Open the petcock, and remove the allen wrench mounted in front of the pump. Pop out the plastic plug in the header and manually latch the roof. Then close the petcock
You should be able to cycle it normally after that.
See also www.jagrepair.com for more info.
Since you disc. The batt. Yes you need to retime the windows, and since you got it stuck and out of time since you didnt do that first. Youll need to retime the top now too. Rtime the windows and press and hold for a few minutes the top button without release. This many timwes will restart the top and allow it to retime without doing it manually
WhiteXKR (04-30-2012)
I am perplexed beyond four b and s's.
Well, I am shaken to the quik.
I tried holding down the switch for milleniums, nothing.
I tried using the door switch. Nyet
I do hear clicks from the back but cant isolate.
No top movement, no window movement. Clicks and pips but no real action.
Time to go to the dealer facista.
God help me.
Bertie
God help me.
Bertie
99xk8guy
06-05-2023 06:28 AM
