TPS sensor repaired to new
My uncles 4.0 had a failed tps sensor, we used this service, the sensor came back brand new looking and works perfect.
1999 02 Jaguar XK8 99 2003 XJ8 Throttle Position Sensor TPS Reman for Sale | eBay
Here is tps and pedal sensor repair company
Jaguar XK8 XJ8 Throttle Pedal Position Sensor TPS PPS Reman for Sale 99 to 03 | eBay
2nd pic is a new aftermarket TPS,it appears you can easily swap your old rotator bracket onto this new tps sensor with needle nose pliers ,needed.I plan to buy a used one and find out.
JAG ROTATOR CUP
![](http://i.ebayimg.com/00/s/NjAwWDY0Mg==/z/YXAAAMXQ4uJSHTRh/$(KGrHqR,!mIFICSTSwueBSHTRhQEf!~~60_57.JPG)
NEW AFTERMARKET ROTATOR CUP
AIRTEX 5S5062
JAG ROTATOR CUP
AIRTEX 5S5062
GEO METRO 1.3L 1994-1997 (96068432)
GEO METRO 1.0L 1994-1997 (96068432)
CHEVROLET METRO 1.0L 1998-1999 (96068432)
PONTIAC FIREFLY 1.0L 1994-1998 (96068432)
SUZUKI SWIFT 1.3L 1995-1997 (13420-50G00)
MAY FIT OTHER YEARS AND MODELS
PART # 13420-50G00
OTHER PART # 198500 3090
The aftermarket TPS may be similar physically as are quite a few TPSs but as far as I have been able to ascertain they are not electrically compatible. I even went as far as to put down a deposit on having 200 of the 198500-3250 made but the initial tooling cost was USD8000 so the numbers didn't stack. Have a look at this old thread for the tech.spec on the TPS - it's the staggered output that counts from the two pot. tracks. Interestingly the TPS is almost certainly fitted to Toyota/Isuzu/Mazda(although the pin numbering may be different) but I can't tie it to a particular model.https://www.jaguarforums.com/forum/x...acement-77560/
...it's the staggered output that counts from the two pot. tracks. https://www.jaguarforums.com/forum/x...acement-77560/
I believe I paid about $350 US to have my TB rebuilt which included more than the TP work.
They're even more of a rip off when you have to buy the whole throttle body at $2400 as Jaguar won't supply them separately- and to add insult to injury they are a known weak point on the car- Jaguar did covert recalls under warranty in certain markets.
RoyLittle0
05-25-2023 02:38 AM
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
