I've spent the afternoon trying to find either how to fix my current switch, or what part I'd even need to look for if I need to replace this. The switch is sticking, causing intermittent loss of speedometer, flashing Trac and Stability control failures, and hand brake. Online, there are may variations. I would appreciate any ideas anyone has.
Those symptoms have little to do with a single sticky switch and more to do with a low or failing battery. An overnight charge may help but do check at the terminals what voltage you have.
This happened after driving the car for 1/2 an hour. I hadn't shut the car down between driving for 1/2 hour, and heading back. Pressing the stuck switch exacerbated the frequency of symptoms.
Spray blasts of contact cleaner. Jam the straw that comes with the bottle into the seam between the switch and the plastic surround. Place a microfiber towel or something below the switch your are spraying to prevent run off from marring other buttons. After you've done this, actuate the button a few times. Repeat if necessary.
I've had this with the hazard button. I removed the centre console and slackened off the screw holding the panel, complete cure. Sometimes the panel distorts in the heat of the sun in the cabin, and it then binds. Silcon spray on the button might also release it. Having said all of that, i think you must consider the symptoms you're getting may also be low battery. These early cars ( pre 2003) were prone to battery voltage fluctuations.
Thank, Mike. This started 1/2 hour into an hour drive. It's all pretty weird. Of course, it's raining like crazy today and we don't have a garage, so poor Brutus must wait.
I have also had issues with the DSC and Hazard buttons sticking. I also loosened the mounting screws slightly and zero issues in the past three years or so.
And that seems to have been exactly what the problem was. Finally got around to loosening the screws and just took Brutus for a long drive with no warning lights! That felt wonderful.
