traction and stability control failure code C1095
Hi folks. On the way to work today the car started giving me traction and stability control warning. Drove it the last 20km to work and the code reader said C1095 pump motor circuit failure. Is there anything I should look at before I take it to the mechanic and can I drive it home about 65km? Thanks for your help.
Received 2,434 Likes
Unless it's already been attended to, most likely the soldering around the pins in the ABS module is failing.
If wiggling the ABS 2-pin connector makes the error go away temporarily you can be pretty sure that's the issue.
OK to drive, IMO:- the brakes will still work fine, just be aware that the ABS function will be disabled.
ozbot (07-22-2021)
Michaelh: Thank you for your reply. Now that I have a starting point I'll search the forum for the repair procedure. I remember reading a few threads about this problem and reading that there's a company that repairs the modules. I'm fairly handy with a soldering iron so hopefully I'll be able to get the repair done but you never know. Also thanks for the info about drivability. I'll drive it home tonight and have a look on the weekend.
