Traction / Stability Fail
Had the exact same problem and it turned out to be a bad sensor at one of the wheels. My indie determined which wheel had the bad sensor, then replaced it and all was well. You may want to try cleaning the contacts on the wheel sensors before replacing any of them.
Stu
Stu
The following 2 users liked this post by StuG:
GroovyMom (04-10-2017),
Orthodixie (04-08-2017)
The following 2 users liked this post by RJ237:
The following 2 users liked this post by Jandreu:
^^ What they said....
Be sure to also inspect the condition of the rubber boots on the speed sensor wiring harnesses where they attach to the sensors themselves. These boots tend to break down and split over time, allowing water and road grime contamination into the wiring. I fixed my wife's 2006 XK8's split rubber boots back in March 2013 by cleaning them thoroughly and applying a big glob of neutral-cure RTV sealant all over them and letting them cure overnight before reattaching the wiring harnesses to the sensors. Now, whenever I do a tire rotation (every 6,000 miles) I check those boots and apply more neutral-cure RTV sealant as needed (probably every couple years or so). No more DSC or ABS warning lights have appeared on her dash as a result of this approach (which was recommended by another forum member whose name eludes me right now)....
The following 2 users liked this post by Jon89:
On cleaning I have done this with good results. 400 grit wet dry sandpaper just to clean the "exciter" rings on the hub. The toothed gear looking part. Upon removal of the sensor from the hub spray some MAF sensor cleaner on micro fibre and wipe off the ends of the sensors. If they have never been cleaned your rag should be black after cleaning. Un do the battery prior to cleaning.
