trans fluid level 1999 XK8
In the process of refilling trans what is correct and where is it documented?
Should the car be level or should the transmission be level.
If it is the transmission is to be level it will take more fluid to fill.
It seems to me ZF would require transmission to be level because
each different car model may sit at a different angle?
Glenn
Glenn
Don B (03-23-2019)
Don B (03-23-2019)
Johnken (03-23-2019)
All of the info read and seen in the past says car should be level , checked on sill or below sill.
But came across one video where tech puts a level on transmission after pan is removed.
Made more sense to me? It does take more fluid this way and required the rear of car to
be raised up a lot, to level transmission. Don"t know how critical fluid level is. Had an XJ6
that when overfilled 1/2 quart would spew it out. Don't think the XK8 has an overflow vent.
Glenn
Glenn
Received 13,203 Likes
CorStevens (03-25-2019)
cchong
10-28-2020 10:57 PM
FactoryJaguarTech
11-28-2019 02:53 AM
