Transmision fluid change
Chaz, there's many a'discussion about that in the XJ area and around the xk8 forum. Dealer will charge 800-1000, mainly because of the high cost of the jaguar fluid. There are other threads that members have recommended other fluids, much more available and affordable. I think you can probably get the job done at an independent transmission shop, parts (filter, gasket), fluid, labor and all under $500. Most important is to acquire your own fluid that you want, get the filter and gasket from jaguar (maybe a few pan bolts just in case) and give them to the shop...that way, all you have is a labor quote to worry about.
I'm sure there are others that can quote you a more accurate number, but regional prices will vary.
There are not many folks with the fitting capability to 'flush' the 5HP24. Lots of discussion about flushes loosing 'crud' but since the fluid circulates continually my little mind has a problem grasping that.
My personal philosophy is to change it at 60k along with the filter and 30k after that.
www.zftranspart.com cheaper prices than a dealer, plus fast delivery! Oh, while you are at it replace the rubber electrical sleeve for $12.00 more!
aholbro1
08-05-2021 05:02 AM
Wes Steenrod
09-06-2015 06:52 PM
