Transmission chirp
Received 6,330 Likes
Can't say for sure, but maybe it isn't bad moment anyway to change the filter as well (I expect it not to be so expense), as some say lots wear material will happen from new (at least with the MB boxes). $600 is not cheap, what are they going to do for that ? Will the oil be fully flushed? Valid point from Norri, maybe someone knows from which date (fill date of the oil canisters) it should have the additive.
I wouldn't throw out my very expensive ATF at just 25,000 miles....
The ZF chirp or bark is just a nuisance. And it may go away. Ours did. Our ZF was barking occasionally in the late summer / early autumn of 2010. Deeper into autumn as the weather cooled off, the barking diminished and then ceased. Coming up on 70,000 miles on the car now. I'll begin considering an ATF drain-and-fill between 80,000 and 90,000 miles as long as our ZF electrical connector sleeve does not develop the dreaded leak....
Norri (03-12-2012)
Marka
22
09-11-2016 12:09 AM
