Transmission Control Module
Beyond this, I'd start at message #1 in the thread below
https://www.jaguarforums.com/forum/x...roblem-124765/
1. CAN bus is inoperative because of intermittent continuity problems on the bus noted by the P1642.
2. Scanner doesn't work well on your car.
Are there any hints as to prior history that could explain any of this? Any repair, inspection, spills, etc. recently?
If you think the transmission is suspect, I would start with the data connector to the transmission in case the connector sleeve is leaking and causing the plug to fill up and fail. It is near/higher than the trans output flange, sort of dead center to the bottom of the car. A bit hard to reach, but doable on jack stands or ramps. There is a twist-lock mechanism that needs paid attention to (only the collar rotates, the plug absolutely cannot rotate). The seals to the sleeve fail "all the time" and are a known maintenance item. Pins in that plug also have a reputation for collapsing when messed with, so double check it. Just a thought.
Best of luck, keep us posted.
PS: do the lights on the shift surround light up and follow the shifter? This illumination is based on CAN...
To clarify, the diagnostics may or may not work, in general, depending on what's wrong with the network (i.e. shorts, or loss of continuity, or loss of termination should prevent function of the scanner), but if the whole network is fragged you should likely see the instrument panel (INST) complaining at the very least when you turn the the ignition on. Good suggestion on the fuses. The diagnosis of the termination does not rely on power, just connectivity or lack thereof between the diagnostic connector pins (ODBII connector) and the network/modules. If it's intermittent, there may be a period of jiggling wires to see which one(s) may be causing it...
The only way to clear the ECM data recorder is to go into SETUP and CONFIGURATION, Special Applications, Engine Data Recorder and CLEAR the data in both A and B sections.
The data will be cleared upon exit from the application if you choose Erase or Delete.(green tick/check mark) (no more P1582)
crbass (05-30-2020)
P0782 TRANS
OBD II
2–3 / 3–2 Gear load fault
Drive the vehicle at 113 km/h
(70 mph), then reduce the throttle angle until the torque convertor locks
Ensure that the torque convertor remains locked for at least 1 minute
TCM Default:
– Electronic limp home mode
— ECM Torque signal fault
Possible causes
Transmission mechanical failure
OBD II
TCM Default:
Possible causes
