Transmission Control Module
Good news, bad news
DSC? As in dynamic stability control? Good news, tis something else. Bad news, tis something else. Do you have a code on this one?
Was gonna say wheel speed sensor. Most common DSC fault seems to be that and it can also affect transmission decisions.
First thing is to remove and clean it. Videos of how to do that on YouTube.
If that doesn't help, check all wiring for damage and then try swapping sensors around to see if the fault follows the sensor. If so, order a replacement.
I have been cleaning all four wheel speed sensors at every oil & filter change / tire rotation (6,000-mile intervals) since March 2013. No DSC warning light issues since beginning the cleaning routine. You do need to check the wiring harnesses for cracks and splits whenever the wheels are off the car, though....
95Leaper
09-27-2016 08:53 PM
