Transmission cooler o-ring size
simple question as i have looked here and elsewhere. does anyone know the size of the o-rings where the transmission lines attach to the radiator fittings. diameter is easy enough to figure out, but o-rings have width which varies by application. thank you.
I had the same issue when I replaced my radiator. I just took the old o ring down to my local NAPA auto parts store and they had a good selection of o rings which you can match individually. A good hardware store should also have a good selection. I don't think the radiator o rings are anything special such as would be the case with a AC system.
CorStevens (10-01-2018)
aholbro1
02-14-2021 01:51 PM
new mexico
05-22-2017 09:43 PM
