The Transmission DipStick for XJ8 and XK8 is Available
#61
There isn't one on his website but I don't believe it has been updated for years. Send him an email he might have already made one. If not he was looking for cars to make a prototype a couple years ago. You are only about 250 miles miles from him. Heck I've been known to drive that far for good Mexican food.
#62
#63
#67
#69
#75
Thinking of the kit for my XK8 only due to fact I'd like to change fluid more often. Otherwise, reading too critical for an accurate reading. ( my opinion). I recently changed the fluid. I know the level is spot on. I can drain, measure and reinstall exact amount with the dip stick upfit. Starting to have problems 1st to 2nd shift when hot on my 99 XK8 ZF 5hp24 trans @ 55k. Had a service tech replace fluid and filter. Worked well for a month. I suspected new fluid ( which the tech said was nasty, no filings) was now diluted with old fluid remaining in converter, etc. I purchased the upgraded pressure valve from trans go for the valve body, replaced filter and fluid again per factory specs to a tee. Proper pump, laser temp tool from Harbor Freight. Much to my surprise, fluid was low 3/4 qt trans fluid. I have around 500 miles thus far and happy to say the trans acts like a new transmission again. Remember. I stated a tech changed fluid already. So, filler plug as well as pan bolts had been removed. Be careful to insure quality sockets to remove bolts and loosen before you drain. Rich
#76
Francois
#77
#78
I know some may scream at this but I have been using Wolfshead Universal Automatic Transmission Fluid in my XK8 and have had zero problems. The guy that makes the dip sticks has a good discussion of this on his site, so I tried it and for me it has worked well. The biggest plus is that a case of it costs about $47.00.
#79
My 99 XK8 has been shifting funny occasionally. I stop briefly and when I step on the gas, the engine revs up a bit before 1st gear engages making for a neck-snapping start.
Today it did this shifting into reverse and again when I went to drive. I suspect low tranny fluid, but it seems there's no way to check this. Any one have a similar issue?
#80
Firstly, please do not drive the car again until it's been sorted.
I had similar things happening in my gearbox before it stuck in top gear.
There was a fault on mine caused by a valve in the valve body, this caused a pressure spike which broke a valve body casting and the A drum. All this would have been avoidable if I'd dropped off the gearbox sump and fitted an uprated valve body piston and spring when the faults first appeared.
