Transmission fault
My 2002 XK8 (48000 miles) has been running great all summer. Have even been thinking about taking it on a road trip. Yesterday about 2 miles from home felt a bump and that little yellow light came on with 3 messages-ABS, Traction Control and Transmission Faults. Does anyone have experience with this combination? Since light was yellow drove on home even though car felt sluggish at low speeds. When I got it in the garage I restarted and warnings were gone. Any thoughts?
Old_Doc
Old_Doc
Hi Doc, stay away from those bumps. All hell breaks loose with the electronics.
As many have pointed out on this forum, sounds like it could be a bad battery or connection. If you hit a bump, could be a bad battery cable connection.
I have notice in the past if I left my XK8 in the garage too long without exercise, I would get the traction control, ABS flashes as well. I since installed a solar battery trickle charger. Battery always feels strong, no longer the strange fault codes. Rich
Old_Doc
Old_Doc
Old_Doc (09-27-2015)
To check, remove the wheel, then remove the sensor (1 bolt). Through the hole, gently check that the ring is solid with the hub with a screwdriver. If not, this is most likely the problem.
Best of luck, keep us posted.
To fmertz:
Just read your reply of 9/27 to Old_Doc re his Transmission Fault problem.
I have an 06 XK8 (4.2 / 6sp auto) with (I think) a 6HP26 trans that is not shifting properly - details in my Gearbox Fault post of 9/24 in this Forum. My sign-in name is jtflanaga.
Would be very glad of any advice you're willing to give.
John Flanagan
John Flanagan
Fmertz - John Flanagon's problem is almost certainly the same one. When it happened to me I was at 80+ mph on the motorway. There was a bump (as if the car behind had bumped my rear bumper, followed by a dramatic drop in speed with ASC not avail, Trac not avail, gearbox fault. That was followed by Limp Mode.
Get a Jag dealer to check the outputs of the TPS.
aholbro1
08-05-2021 05:02 AM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
