Transmission Fault
Hello All,
I’ve had an ABS, Trac fault light intermittently for a while, I had changed all the wheel sped sensors and that didn’t change anything. The car eventually started “ Stuttering “ when accelerating up the gears. Felt like one of the wheels grabbing.
I borrowed a Code reader and found the ABS Module had a fault. I bought a repaired one and installed it. Started the car all lights were extinguished, so I backed the car down the driveway and started a drive. About a mile down the road, I stopped for a stop sign, made a turn and begin accelerating. I think the shift from first to second is where the car “ stumbled again and I got a transmission fault warning. I turned around and went home. Now accelerating the car felt like a slipping clutch, more than usual revs and slowly accelerating. I turned the car off, waited a couple minutes and stated again. All is normal again, but I don’t want to drive and make things worse.
Thoughts?
Oh, by the way....2001 XK8 110,000 miles
Thanks, Jack
Thoughts?
Thanks, Jack
Sorry to hear about the transmission repair cost.
Was your 2001 MY the ZF5HP24 gearbox? If so, it’s another in a long list of A Drum failures, a known weakness. ZF do an upgraded A Drum, which I presume your mechanic is putting in. Plenty of rebuild kits available and an upgraded PR valve too. Maybe a good time to overhaul the valve body too, including the solenoids. The F channel in the valve body case is known to crack too. Make sure you have an OEM filter as after market filters are known to “whine.”
crbass (10-12-2019)
