Transmission Fluid Change / Fill from top / squeal bark sound
A lot has been written and speculated about that here. Some of XK have the squeal sound when upshifting under full load.
I had that sound. So I thought instead of filling in additive I just change the trans fluid. Well, easier said then done. I drained the fluid. Got most of it out as I ended up with about 8 quarts of old fluid.
But trying to refill the trans fully through the hard to get to fill plug is an ordeal. I even ask the tech and my Jag dealership if there is a trick. He responded "most of us are ending up wearing the wearing trans fluid and the shop smells for 2 days.
So, I picked up on somebody's idea to fill through trans cooler hose. Guess what? That is SOOO MUCH EASIER.
Just disconnect hose on top of trans fuild cooler (left side of radiator top). Get one of those hose attachment thingies for oil bootles, a funnel or whaever works. I slid a clear tube right over the attachment nipple of the hose and filled the oil in. Obviously it runs downward. Of course make sure you check either make sure you fill in same qty you drained and check level as per procedure specd at bottom fill plug.
I didn't spill a drip of trans fluid AND the trans is now shifting like well, as perfect as can be. And the squeak noise is gone, too.
So, don't even try to get a hose into the bottom fill hole. It keeps sliding out, spilling and so on. Can't get to it easy anyways. Fill through cooler hose. The fluid ends up in the same place.
Orthodixie (04-02-2017)
Oh yes and.....I simply used Valvoline MAX LIFE DEX/MERC. After some research and looking at spec sheets I didn't see any benefit to use anything else. It's synthetic and exceeds all specs. Jaguar or not, its a German Transmission also used in Ford and other cars. Just because we have a leaper on the car doesn't mean you get more if you pay more. At least that is my personal opinion. Mileage on my 2003 XK is 72,000
I just changed my fluid/pan, so by the end of the day tomorrow (or maybe even tonight) I'll have a video uploaded.
Mish, I'm not sure about your car because it has a different transmission than mine, but on the 2003+ XKs there's no way to measure the fluid level if you fill it the way you described. You can put back in the same amount that came out, but what if it was low?
Gears, I just looked at the Valvoline website and they say that the Max Life is compatible with Mercon SP. That's what is used in the Ford version of the 6HP26. But it also says it is compatible with Mercon and Mercon V. That's odd because every other brand of ATF I've looked at treats Mercon V differently than Mercon SP. The other brands all have an ATF that is compatible with Mercon V and then another that is compatible with Mercon SP. They say not to mix them. The Max Life is the first one I've seen that says it's compatible with either. That's kinda weird...
The following 2 users liked this post by Reverend Sam:
Danster (03-04-2011),
This will be my longest video ever. It's 28 minutes plus commercials. It's rendering right now, but my computer isn't very fast. Then I'll have to upload it. Then write up the description... Hopefully I'll be done tomorrow morning. I'm getting better at editing, but I need to learn how to bleep the dirty words. This video is going to be a PG-13 for sure.
gears (03-05-2011),
Yesterday I got a hold of Amsoil ATF , so now I will do full drain (hopefully utilizing your technique) and refill with Amsoil.
Ever since I did four initial drains and fills, my transmission has not had a single freak out, where it would downshift to first gear and then get stuck in it until 3500rpm, then shift up with a major jerk.
So now is the perfect time to do a final flush with expensive, permanent fluid.
Referend Sam, I tripped over the same questions with the Valvoline Max Life and thought the same thing. Weird to be compatible with all of them. I went to the Valvoline Website, and in addition compared the detailed specs of the different oils. Seems to be fine. I am no expert so I relied on what it states. Im mean Valvoline is a brand name. I can only assume its OK based on the specs.
Filling from top is OK, but I do recommend to check level afterwards per the specified procedure. (At the fill plug, correct temp and shifting through gear selector as specified.)
I am just happy the trans works like, well, I can't think it could be better. Like new or even better.
I thought I did state regarding the bark noise. Well, it did the trick. That noise is gone. I had it out twice on the backroads. ONce with a fairly cold trans and then with a hot one. In both cases no more bark noise under full load. That was the reason I did it in the first place. I knew it was trial and error. But rather then using an additive I chose the Valvoline Max Life as it already has all kind of additives in for older or noisy trans. All I can say, it worked on my 2003 XK8 with 72,000 mls on.
One more thing. My old trans fluid looked and smelled pretty OK after the 72,000 mls. Not too brown or smelly (besides the inherent weird smell it has). So call me an idiot, I did not change the pan and filter. Didn't see the need and didn't have the parts. BUT I am not recommending it. While you are going through the hole thing it makes more sense to do so. And probably should have. I don't thing it will be an issue though. Trans is sealed and meant to be left alone for life anyways. Time will tell.
I just completed the change of my transmission fluid and filter on my '99 XK8. I just couldn't believe the fluid was "life-time". I am glad to see other people have changed the fluid as well. I have 55,000 miles on the car. I was able to find the Esso ATF LT 71141 fluid and it cost me US$19.81 / qt. Before I launched into this project I read up on the 5HP24 transmission on the ZF website (www.zf.com) the Bulletin TE-ML 11 was very interesting, especially where it provides a complete list of the 11B compatible fluids on page 5. (Esso AFT LT 71141 is listed under 11B) I would love to find a chemical analysis of the difference between all of the different types of fluids. When I used to help at my Dad's you knew it was transmission fluid because it was red. Ha Ha what a difference today.
I just realized that my "bark" is completely gone. I added a bottle of the additive about 6 months ago, but it didn't completely eliminate the problem. I still had a little chirp between 1st and 2nd when accelerating hard. It was still there after putting in the Mercon SP, but now that I've put a few hundred miles on it, the bark is now non-existent.
![Icon Attention](https://www.jaguarforums.com/forum/images/smilies/icon_attention.gif)
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
Sam has made a video.
https://www.jaguarforums.com/forum/x...deo-faq-50868/
You have the 5 speed ZF, not the 6, but I believe the procedure is similar.
It's certainly not the approved way but it's worked for me on other cars.
I have a copy of the Bulletin if you would like. I tried to attach the pdf to this reply but I cannot see how that is accomplished. I am new to the forum so I might be missing the obvious.
By the way, in my opinion, the CARS in the "Girls on Cars" thread are optional. As long as you post a picture of a sexy babe I think you've fulfilled the spirit of the thread.
