Transmission goes into Limp Home mode
Hello. I have a 2002 XK8 with 15,000 miles. I have had the car for 10 years and have a nagging problem: the transmission works fine unless I use it to downshift such as when slowing to a stop from Interstate speeds. I may drop it one gear or two. About 50% of the time when I place the gear lever back into the normal position (D), I receive the "Performance Restricted" message and indeed the cars acts as if it is "Limp Home" mode. I can clear it by turning the car completely off and then restarting it.
Is this a mechanical or software issue?
Is there any "fix" for this?
Thank you,
Bill
Thank you,
Bill
Received 2,675 Likes
I assume that other things have been serviced over the last decade?
