Transmission pan bolts
I am probably going change the pan/filter and replace the trans fluid very soon. I have read that the earlier torx head pan bolts are prone to stripping. The later , more robust ones run about $3.00cdn each. Why can you not just use a normal hex head bolt with an appropriate washer ? Is there something obvious that I am failing to see ?
Received 6,332 Likes
Received 2,670 Likes
