Transmission seal leaking question?
It could also be a leak from the ZF electrical connector sleeve (a common issue with these cars). The replacement sleeves sold today have been redesigned and we hope they are not prone to leaking as the factory sleeves are. I don't believe that anyone who has changed this sleeve has reported that the improved version leaked as well. It's an inexpensive part, less than $20, but you must drop the ZF pan in order to change it (which means an ATF drain-and-fill along with the sleeve change)....
I would find out exactly where this leak is before pursuing the car....
I'm thinking that might be part number JLM21109 for us earlier XK8 guys. They didnt replace this when I had my transmission rebuilt recently so I think I best do so before I drop the trany back in assuming the older XK8s had the same issues?
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
