Transmission Service
Brought the 55k mile Tiger home after the transmission service completion. Yes, it is expensive.
As previously noted, once in a blue moon my XK8 is a little delayed going into reverse, a little lazy on down shift to first. I have had her jump into first with a wheel chirp after multi stop signs only one time.
My Master Jag tech stated the fluid was a bit dark and burnt looking. No hard clutch material or hardware found in the pan.
My 50 mile drive home note radical improvement in shifting. Way too, too smooth for my liking in the past. Seems like a new transmission.
All my symptoms pointed to foul/ poor oil. Time will tell. I am hopeful the improved performance will stay without major overhaul in the future.
Rich
Rich
We have them, but there have been so many warnings on the forums about possible damage from materials forming hard deposits becoming suspended that many are avoiding the forced flush. Whether true or not is hard to prove either way.
Having a lift, I don't find it inconvenient to do multiple changes, and don't like others working on my cars if I can avoid it.
