Transmission shifter face plate
Shifter Trim
Here's one on ebay -
https://www.ebay.com/itm/2000-2001-2...ty!20170!US!-1
It's a little pricey, but maybe you can look around for some more.
That one won't work on cars with 6 speed.
Felipe Pr (11-04-2019)
This seems to be a bit of a problem part. Not readily available new, and used parts hard to come by. You may have to wait until something comes up on eBay, but there are other options
- See if you can somehow repair it with some sort of plastic filler, sanding and a lot of patience. The silver graphic part may have to be redone somehow
- There is a gentleman on eBay that does a batch of "chromed" plates once in a while for a decent price. They typically sell out over time, and there are gaps in availability. His vendor account is listed on this forum. Use search
- Someone once posted pictures of a leather shift boot, just like a manual shifter. It covered this plate completely, and, from memory, wedged between the surround and this plate. Looked good to me, but of course none of the markings were visible, which may be a problem for someone driving this car infrequently (spouse, valet, etc.) as the dash does not show what gear you are in either.
- Post a wanted ad on the classifieds on this forum
Received 12,941 Likes
I do remember seeing his posts on ebay but can’t find them now. Do you have his contact information?
What happens to these plates to cause them to go? Do they become friable with age, and just die without explanation, or are they damaged by the driver in gear selector semi automatic mode, or what? I am asking because my plate is fine, but if the future is likely to hold damage or disintegration of this part then a spare might be wise. I also wonder if there is anything I should be particularly careful of doing to avoid future trouble.
And...just a thought. I wonder if any other models have plates that could be made to fit. If the lever movement us the same, or close, perhaps....?
LoudHogRider
03-06-2017 07:38 PM
