Transmission "squawk" ( or "whoop")
#41
The noise is created by the ZF internal clutch packs grabbing just a fraction of a second too long during shifts. The friction modifiers in your ATF are worn out and that is what causes the issue. The fix is indeed an ATF drain-and-fill. Plenty of threads here on the forum confirming that, and so do I. It immediately silenced my wife's 2006 XK8's squawk when we did a ZF drain-and-fill back in July 2013....
There are several ATFs other than Lifeguard 6 that meet the required Shell M1375.4 specs. Do your research, pick an ATF, and do a ZF drain-and-fill. You'll then enjoy silent shifts again (as well as a longer-lasting transmission)....
#43
The noise manifests itself in different areas in different cars. Do not be fooled by where you THINK you are hearing the noise. In my wife's XK8's case, the noise sounded as if it was coming from the rear axle. I knew from experience that it was indeed the infamous ZF squawk....
Last time I'll say it - Do a ZF drain-and-fill. You're just wasting time and brainpower until you do....
Marka
22
09-11-2016 12:09 AM
dmatthewman
09-30-2015 10:10 AM
