transplanting the new engine 5.0 supercharger on our XKR 4.2 x100
I have been wondering the same thing as used 5.0 SCs are relatively cheap.
My questions are: What about charge cooler to SC connections?
Pulley line up?
SC bypass relocation?
Breather pipe connections?
Air intake connection?
EGR connection and electrical control?
Throttle body location with no elbow?
I do not think these things are insurmountable but how difficult to actually do? The last
2 on my list above seem to be the most difficult?
Pulley line up?
User 070620 (12-07-2016)
Engine is easily 7500 euro over here (you want a good on to start with right?, maybe also a new gearbox?), but the costs are not in the 2nd hand engine, unless you are able to fabricate lots of parts yourself, let alone get the electrics going by yourself as this a completely different type of engine.
It would be so much cheaper to bore out/stroke a 4.2 engine, but as said all depends on the budget you have though, as there is no cheap thing here...
JagSTR2004 (12-07-2016)
Disclaimer: I have no direct experience with this. My car is the way it came from Jaguar.
You might want to look into the Jaguar Specialties LS conversion for an approach. The short version is that you need to consider transplanting the engine, transmission, harness and associated electronics as one unit as they are meant to tightly work together.
Then you need to work on all the mechanical aspects (engine and transmission mount points, clearances, driveshaft, fuel supply, cooling, etc.).
Last, you will need to somehow make the rest of the car electronics work with the transplanted electronics. Even if both the old and new electronics communicate mainly over CAN, it is likely you will need some form of bridge/translator so that messages can flow between the new and old modules, and meet all expectations on both sides. I believe Jaguar Specialties developed and now sells such a box, but for the GM ECU on one side and the older 4.0 XK8 body on the other (i.e. useless to this conversion). I believed it required ad-hoc reverse engineering, not something entirely easy. Also, JS sells a detailed conversion manual for mechanics. This might contain enough information for you to find out what you are getting into. My sense is that finding "cheap" donor parts is the least of your problems, but it seems like a fascinating challenge.
Best of luck, keep us posted.
The following 2 users liked this post by fmertz:
Superchargedxkr (03-12-2023),
User 070620 (12-09-2016)
AJ133 swap into X100 body and connecting modern engine with prehistoric transmission, steering, suspension and brakes of X100? Pure waste of time and money, IMHO.
If you want to complicate things, go to twin screw. Even stock 400 HP is more than poor suspension can handle if driven really hard on twisted roads.
thank you all for your ideas. I also read that some of you have asked "why do this"?
mine was just an idea in order to understand the level of difficulty. I often read others members of this forum that have put the supercharger on aspirated XK8 ... or others who put the engine on 4.0 versions 4.2, or transplantation of manual transmissions in place of the automatic transmission.
All these members of the forum have made a great effort (both economic and time) to accomplish something even it was enough easy to buy the latest version or buy the model with the supercharger and the game was done!
but I do not I never asked "why do it?". but I appreciated their efforts and we must be grateful to them all for letting us see that this is possible.
I probably do not have sufficient capacity to be able to do this transplant. But surely it would be a fascinating challenge!
The following 3 users liked this post by User 070620:
Catching up on postings. This thread is similar to an older thread back in 2010-2011, but the old thread has more details on the 5.0 engine. Here is the link.
https://www.jaguarforums.com/forum/j...-engine-32738/
I was thinking about using a 5.0L engine for a higher HP engine build versus the 4.2 as the baseline. After a few messages with Count Iblis, decided that sticking with the 4.2 will give me a stronger engine for a 700+HP. On the plus side, one doesn't have to deal with the 5.0L's oil pressure driven inlet VVT tappets/lifters.
The following 2 users liked this post by Tijoe:
User 070620 (01-16-2017)
