Trunk Accessory Socket - RESOLVED
Hi All,I have had a search on the forum but cannot find the answer, so maybe one of you experts may be able to help.
I am looking to put power supply into the trunk I have an accessory socket there already which I can fit three female lucar connectors into but I am looking for the correct plug rather than just poke three wires into the block. Any part numbers or advise would be great please.
Thanks in anticipation.
Last edited by GGG; 10-06-2014 at 06:13 PM. Reason: add 'RESOLVED' to thread title
Here is the official Jaguar accessory, but I doubt it is still available: http://jagrepair.com/images/AutoRepa...owerSocket.pdf
Note that you will also need to add a relay at the 'R6' empty location in the trunk fusebox for switched power to be available. It is the same type as the other brown relays in the fusebox.
Flighty (10-06-2014)
Collector1
09-26-2015 05:28 PM
