Twisted Seatbelt
Twisted Seatbelt
My seatbelt is twisted thus:
I noticed the hex bolt on the floor, but knowing Jaguar, I can't imagine it's as simple as removing the hex bolt, lifting the rod, sliding the belt loop off and untwisting it, then sliding it back on and bolting the rod back down. There's gotta be a trick somewhere in the process to get trapped by.
Is it really that straightforward? Must be getting JagDIY paranoia...
I noticed the "Jaguar" label at the bottom of the belt in facing inside the cabin on both driver's and passenger's belts. Shouldn't they be facing the same direction? The passenger belt is not twisted.
The labels should both either face in or face out. The belts are unique to each side.
If the belt retracts fully and quickly, then twisting in the reel is less likely to be the cause. But, you have to pull them all the way out to determine this, not just to your usual position.
In that case, it is a case of remounting the seatbelt.
You need to lookup whether or not you have pretensioners in JTIS to get a definitive answer. It is an explosive device. If you blow it, you get to buy new seatbelts. They are not cheap.
Skid Mark (01-14-2012)
Sounds like a dealer should correct that.
you cannot put the driver belt on the pass and vs. the ball locking ramps will keep you from pulling the belts out. you dont have to do anything more than taking out the torx bolt and flipping the belt. THIS IS ASSUMING its not twisted. Pull the trim off around the belt where it goes into the back seat casing and pull it out to check with a small bright light. It can twist and there is a metal straightener behind the panel you cant see that if the web has gotten twisted behind it you wont see it or know. it will keep it twisted behind it. if this is the case just double it over on itself and feed it back through to straighten. FYI. unhook battery?? never done that
Wouldn't mind except it makes it a pain to put on and also a twisted belt isn't as strong as a straight one in a collision.
Any problems with unbolting the floor mount and taking the twist out down there? My concern is with getting the bolt back in, and any structural issues that might occur there. Carpet covering the floor, can't really see the site.
Skid Mark,
The Parts Catalogue shows the hex bolt, a spacer and a washer:
XK8 Seat Belt.pdf
This has to go into a captive nut like the seat runners so looks like a straightforward removal / replacement.
___________________
2005 XK8 4.2-S Coupe
XK8 Seat Belt.pdf
___________________
