Tyre size
Hi All,
My 2001 XK8 came fitted with Dunlop 245/45 ZR17" tyres when I purchased it last year. I know the correct side profile is 50% (not 45%) but, given that Pirelli has the virtual monopoly on that line, the price is extortionate - cheapest I can get is around EUR250 per tyre, while I can get the 245/45s for at least EUR100 less per tyre. Does anyone know if having a slightly smaller side profile on a tyre matters in terms of handling, stability, etc. Obviously, ride quality will be marginally poorer on a 45 compared to a 50.
I was told by one mechanic that the ASC can be more prone to kicking in if the wrong tyres are fitted to the car, but that sounds like a bit of a red herring to me.
Thanks in advance.
Jonathan
Thanks in advance.
Jonathan
Here's my advice. Purchase 255/50/17 tyres. I spent $1000 on 245/50/17 Michelin Pilot Sport A/S tires, but then I discovered that there are many options in the 255/50/17 category, and it will not affect your speedometer much. Check out several options at www.tirerack.com. They also show revolutions per mile that you can compare. Cheers.
Guest
Posts: n/a
i'd have a look at www.blackcirlces.com if they operate in ireland, you buy the tryes direct and have them fitted at a tyre centre of you choice.
look at www.etyres.co.uk as well
for your size as you mentioned:
pzero £156
falken £120
toyo £140
and cheapo 'nexen' £82
hope its of some use
pzero £156
falken £120
toyo £140
Hi snowdmc,
Thanks for the links. I called both firms, and while they don't offer a service in the Republic of Ireland, they do in Northern Ireland, and it works out significantly cheaper than my best quote so far. Looks like about £197 (EUR217 at current exchange rates) for the P-zero including fitting, balancing and disposing of the old tyre. Will save me a good EUR100 on a set of tyres!
Cheers!
J
Cheers!
J
Collector1
09-26-2015 05:28 PM
