Tyre (tire) size
There is a website call automobile catalog that you can look up your car and it will give you alternative tire sizes. All the alternatives are within 3% diameter of the stock 245/50 17 size. I was off a litte in that the 235/55 17 tire is plus 1.9 %. That means when the speedo says 100 you are acturally doing 101.9 MPH. I was OK with that as I wanted to make my car "taller" in both gearing and ground clearance. I had 245/45 17s on the car when I got it and they were really to "short", ground clearance was a issue.
Johnken (05-28-2020)
