U joint grease nipple
Usually the "grease zerk" can be removed with a socket & extension and cleaned. The covers are are available on E-Bay USA and perhaps UK under "grease zerk covers" or google them. the Zerks (available in Standard thread and Metric) are usually able to be freed by proper fitting of grease attachment and forcing new grease through it. plastic covers work well also.
The GN was reasonably easy to access in this position, it unscrewed easily with a 7mm socket and extension bar.
![](http://www.racediagnostics.com/home/uploads/images/jag/grease_nipple/gn%201.jpg)
Once on the bench I was able to clean it up and poke it in the end with a pick to free up the ball.
![](http://www.racediagnostics.com/home/uploads/images/jag/grease_nipple/gn%202.jpg)
I was then able to pump grease through it no problem.
![](http://www.racediagnostics.com/home/uploads/images/jag/grease_nipple/gn%203.jpg)
Back on the car, and all greased up!
![](http://www.racediagnostics.com/home/uploads/images/jag/grease_nipple/gn%204.jpg)
The following 4 users liked this post by RaceDiagnostics:
Hey Racey,
Great that you got the problem fixed, but now I think it might be time to get a pressure washer cleaning in that area-------yuk!
I better look at mine also......
Hey, I notice your coat sleeve in the picture, is it getting that cold over there already?
Hey Racey,
Hi RaceDiagnostics, thanks for the great pictures. This is a job I'd like to do as well but I no longer have a grease gun. Are the UJ nipps. a particular pain to access (I only have jack/stands etc., no hoist) or will a bog-standard gun do the job?
I was thinking of this one:-
https://www.machinemart.co.uk/shop/p...ece-grease-gun
Many thanks, Andrew
Many thanks, Andrew
multiplecats (09-01-2015)
Camnelson324
09-27-2015 08:48 AM
UKnFor-dluv-expat
09-26-2015 08:40 PM
