UK headlights switch to EU?
Old 12-12-2011, 09:07 AM
dibbit's Avatar
Originally Posted by jamjax
.......What's the attraction to Spain compared to that? Sunshine more than three days a year is vastly overrated.....hahaha.
All very true, but the beer is cheaper here.
Old 12-13-2011, 10:29 AM
GGG is offline
Received 16,868 Likes on 12,186 Posts
Originally Posted by avos
It's a simple change, you’ll see what to do.
The good news is that you will be more than likely able to sell the deflectors again, these are for the 4.0 cars, all 4.2 cars have hids.
Avos,
Is that plate reversal quick enough to be an alternative to using stick-on "beam benders" for those of us who cross La Manche a couple of times a year?
Old 12-14-2011, 11:36 AM
Frog's Avatar
In a word, no. Fitting the plates requires dismantling the headlight. Beam-benders are fine for occasional trips over to the continent, particularly if you are on a UK number plate.
The only reason I am doing the permanent conversion is because stick-on beam-benders won't pass the French MOT: they are seen as a non-permanent 'fix'.
GGG (12-14-2011)
Old 12-14-2011, 11:45 AM
jamjax's Avatar
Frog....use Super glue....just trying to be helpful....and er, um don't tell them your Handle on here....
cheers,
jj
Old 12-14-2011, 12:50 PM
GGG is offline
Frog,
Thanks - I'll "stick" with the beam benders or black tape.
What do you do about the French requirement to carry a set of spare bulbs in the vehicle? Any old set do to comply or must it actually include the super-expensive HID's?
Old 12-14-2011, 01:06 PM
Received 1,231 Likes on 716 Posts
In theory, bulbs that fit your car. In practice-----
To get hammered for that one you would already be in trouble for something else, especially if you are on foreign plates.
But you do remind me.
Old 07-01-2012, 11:18 AM
RickDB's Avatar
Default Importing USA spec. XKR to UK - an update
My 2003 XKR (US spec. LHD) arrived in UK undamaged and in tact.
Jaguar couldn't (wouldn't?) give me a Certificate of Conformance so it had to go through the VOSA exam I chose the Beverley test centre. The LHD headlights were pre-tested at a local MoT centre (Bob Trice Mechanics - excellent service close to VOSA) so the headlamps were not changed or adjusted and passed the tests. The only problem with the VOSA test was that the Pirelli front tyres didn't have the "97" load rating embossed on the side, although the max. axle loading was clearly marked in both lb and kg. However, a copy of the Pirelli spec. sheet from their web site showing conformance was sufficient proof. Getting a registration number and first tax disc only cost 275 pounds - which was a pleasant surprise because I thought I was going to have to pay more than 1,000 pounds.
The XKR will be living in France next year so I'll have to go through the CT there - but that will be another story!
Thanks all for your input. Cheers, RickDB
rentzoo
11-10-2015 04:56 PM
1964Daimler
09-09-2015 11:28 AM
avern1
09-08-2015 06:25 PM
Mosers63
09-06-2015 02:53 PM
laserguy
09-03-2015 02:02 PM
Quick Reply: UK headlights switch to EU?
