UK headlights switch to EU?
Is that plate reversal quick enough to be an alternative to using stick-on "beam benders" for those of us who cross La Manche a couple of times a year?
The only reason I am doing the permanent conversion is because stick-on beam-benders won't pass the French MOT: they are seen as a non-permanent 'fix'.
GGG (12-14-2011)
Importing USA spec. XKR to UK - an update
My 2003 XKR (US spec. LHD) arrived in UK undamaged and in tact.
Jaguar couldn't (wouldn't?) give me a Certificate of Conformance so it had to go through the VOSA exam I chose the Beverley test centre. The LHD headlights were pre-tested at a local MoT centre (Bob Trice Mechanics - excellent service close to VOSA) so the headlamps were not changed or adjusted and passed the tests. The only problem with the VOSA test was that the Pirelli front tyres didn't have the "97" load rating embossed on the side, although the max. axle loading was clearly marked in both lb and kg. However, a copy of the Pirelli spec. sheet from their web site showing conformance was sufficient proof. Getting a registration number and first tax disc only cost 275 pounds - which was a pleasant surprise because I thought I was going to have to pay more than 1,000 pounds.
The XKR will be living in France next year so I'll have to go through the CT there - but that will be another story!
Thanks all for your input. Cheers, RickDB
rentzoo
11-10-2015 04:56 PM
1964Daimler
09-09-2015 11:28 AM
