Ultra Gauge??
Have any of you installed an Ultra Gauge on your pre 2000 XK8? If so, what worked, what didn't, i.e., how many parameters did it pick off? Would you buy again?
( UltraGauge OBDII Scan tool & Information Center )
Thanks,
Scott
Thanks,
Scott
Scottsgreenjag (04-29-2016)
Scottsgreenjag (04-30-2016)
Mainly it will be used to monitor the water temp. Kinda hard to understand why Jag used a gauge that doesn't tell you what the actual temp is...
Wasn't aware that there five different versions of OBD II. I think my Rover LR3 (Ford design) uses the CAN protocol so I hope it doesn't confuse this thing if I buy it.
When you set the gauge up there is short list of protocols you select on the display. Once you have selected a protocol it will start with it every time.
I have used mine to read codes on other cars, such as Ford, and it will select the proper protocol. Then when I put it back in a Jag I have to force ISO 9141 again. A very minor inconvenience.
Scottsgreenjag (05-01-2016)
Really like this little tool, have it always connected, and I check for instance stft/ltfts temp etc. It can read the standard odbii codes, and reset.
For serious trouble shooting I use the IDS, but to have something at hand to directly read/check without the need of a phone/pc or is very useful.
Diavolo
09-23-2016 08:38 AM
GordoCatCar
04-24-2016 06:36 PM
