Underbody rust protection
Hi,
I have a 2001 XK8 with only 63k miles that looks like it’s hardly been used in the wet but I will now be using it as a daily car so I won’t to get it protected against rust.
a local 4x4 specialist does underbody cleaning and wax oiling but they don’t do cavity or sill injection. The price is quite high at £450+vat.
based on the common rust points for these cars is it essentially to have cavity injection? The underbody all looks good but the rear subframe and suspension has a lot of surface corrosion.
thanks
kevin
thanks
kevin
Rust on the rear subframe is common. The subframe is substantial and it's more a case of being unsightly. The "A" Frame beneath it also rusts but it can fail as a result.
Have a look for threads by RaceDiagnostics for identification and rectification of most of the corrosion problems that can occur with the XK8.
jackals
05-04-2019 08:04 AM
