Undertray/valance replacement
Has anybody replaced their undertray/valance recently - or am I the only one who has that part beaten up often? It happened twice within the last 2 months already - once on my way to mass, the church driveway has a little dip, and the other just this weekend when there's a slight bump on a restaurant's driveway .....
Is it a straightforward DIY-type work or do I need special tooling for it?
There's also a rubber strip at the bottom that seems to get stripped easily. The strip does not seem to do anything except provide a few inches of 'buffer' before the plastics - or does it?
I think its a DIY job. But the part is probably expensive. It think it is a very hard fiberglass. (kinda like the piece on top of the radiator)
try using a upholstery clip remover to pry it out. if that doesn't work a body shop will have the 10$ tool
My car looks like it is 4 inches off the ground, so ive always wanted to lower it. But every time I smash this valance on a parking block I remind myself that Its good to not be too low.
I just finished doing this. (See this thread for why: https://www.jaguarforums.com/forum/s...ad.php?t=40419) You won't be able to reuse the rivets, so make sure you head to NAPA, etc. for some generic ones (the Jaguar ones are difficult to source and expensive). I used these . The tray is pretty easy to put in. I've never damaged this tray in normal driving, but I'm used to driving low vehicles. Here is a tip: enter driveway dips at an angle for far fewer problems.
RoyLittle0
05-25-2023 02:38 AM
KarimPA
09-12-2015 08:15 AM
Wes Steenrod
09-06-2015 06:52 PM
KarimPA
09-03-2015 07:32 PM
