Unusual coolant leak?
I have, what was until today a minor coolant leak near the front of my 1999 xk8. Sometimes there are a few drops or even a silver dollar sized leak of coolant under the car, at the front, near centre... On my way home two days ago, the coolant warning came on. I got the car home fine, when the engine cooled I checked the reserve. It was 3/4 empty. I left the hood up and the cap off to remind me to fill the reservoir before driving. I went down to the garage today and there was about 1 litre of coolant under the car( that much water to fill the reservoir to overflowing). I could see drips coming off the front of the pan, with a light I checked the water pump , it looked like a dry trail of old coolant but nothing that left it wet. With the "rad" cap on there is no noticeable leak, with the cap off it starts to drain/drip slowly. Anyone heard of this? there are drips off the front of the pan, rad is dry and seems fine. I still suspect a water pump but in all my years Ive not seen a rad cap stop a coolant leak, a low pressure effect of some sort I guess. Anyone experience anything like this?
Do a coolant pressure test. You can rent a kit at autozone or any of the of other big parts chain stores.
StephenLouis (07-30-2021)
How old is the reserve tank cap? I had to replace my tank due to age and leakage last year but foolishly thought the old cap was still serviceable. It is not, and the reserve tank would allow coolant to blow out. A new cap fixed it instantly!
The following 2 users liked this post by Redline:
giandanielxk8 (07-30-2021),
Well I changed the water pump today, as I did finally catch it leaking. A thankfully easy job...when I removed it I found signs of past leaks, and did a clean up and minor repairs where there were old tracers. I also found a leak , following a trail from the top of the water pump upward to a long very brittle PVC/plastic line from the expansion pipe to the top of a sort of coolant transfer station for lack of knowing the name of the part with about 200 outlets/inlets lol. Now just a minor oil leak to deal with. I think cam button.
