Upgrading my XK8
Upgrading my XK8
I Have all of this on it's way, it came off a wrecked car with 90k. It has everything from the heads up, except the wiring harness and coolant lines. Does anyone know if the XKR models have different internals? If so, can I use my internals, or would they cause issues? I know they have different compression ratios. Does anyone know based off of the pic if there is anything else that I will need to change from aside from possibly the fuel pump/adding a pump? Any advice or information is greatly appreciated.
Received 1,700 Likes
Received 2,420 Likes
The following 5 users liked this post by michaelh:
As far as ECM, I'm going to have it tuned to compensate for the upgrades. Possibly change ECM altogether.
I'm mainly trying to find out what parts I still have to purchase/change. I understand the size of the job, I just want to do it correctly.
The parts that are coming: heads, valve covers, plugs, ignition coils, intake, supercharger, fuel rail, injectors, throttle body, amongst some other parts. I can add more pics if needed.
I would keep your heads with the VVT, you will need an XKR crank pulley to drive the blower and I would keep the boost way down like in the 5# range because of the compression issues mentioned above. I would be wise to get a boost-A-pump on the fuel pump (not sure that is an option on the 05) for some additional fuel. The factory computer should be able to compensate for the rest. You will also need to fabricate a pump and heat exchanger system for the intercooler, again not plug-n-play easy but not complex.
That is going to be a bigger project than it seems on the surface but the fun ones always are! Nothing you are doing to your car that cannot be undone if it doesn't work out (assuming you don't throw a rod or melt a piston!!)
that is a big number on a stock high compression engine. You honestly may need to go to XKR pistons, at that point you are either rebuilding your block or swapping it out. If you swap it out you get the better pistons and oil jets (not sure the XK8 had them). It might we worth a discussion with a head gasket maker to see if you can have an MLS gasket made that is a little thicker to help lower compression. I am in the middle of building an engine and I will tell you first hand, to do it right is NOT cheap or easy. Forged Aston Martin crank ($ first born son), forged rods and oversized forged pistons ($5000), block work ($2000), head work (no idea, not there yet), gaskets, bearings and misc parts ($1500-2000).
Either way, document your progress for the forum, there some brilliant folks in our ranks. These cars are finally at the age and price where people are not afraid to push the limits.
