Upper radiator hose
![Talking](https://www.jaguarforums.com/forum/images/icons/icon10.gif)
This last weekend I was putting in some coolant to resolve the second "engine coolant low" warning light.
Upon inspection I notice that the upper radiator hose from the thermostat housing to the upper passenger side (U.S.) of the radiator was compressed, like it was under vacuum. Looking closer I saw that the hose had slipped about 1/4 inch. The clamp was a little loose, so I tightened it, and thinking that was odd, I added a second clamp as a back-up. I've had kitty for a year and have never taken that hose off.
ADVICE- Right now, today after reading this, go check your radiator hose clamps to ensure they are snug and that no hoses have slipped. I've read on the forum how some people have been driving down the freeway and have had their radiator hose come off. Now I see how...
![Icon Banana](https://www.jaguarforums.com/forum/images/smilies/icon_banana.gif)
I would suggest that your plastic radiator cross over pipe is failing and that the upper hose, and probably the lower hose needs replacing.
The plastic cross over pipe is famous for deterioration and leaking, as is the plastic thermostat housing and outlet pipe.
If you are going to open up your coolant system it would be a good idea to replace everything at once.
All hoses
Radiator cross over pipe
Thermostat housing with outlet pipe. Use the new aluminum version.
Thermostat
Water pump
Love this picture!
![](http://api.viglink.com/api/click?format=go&jsonp=vglnk_142470017058412&key=d92373423436cd6f57cd0cabc6847854&libId=d168dcc4-f22c-410c-b755-dc91a189b27d&loc=http%3A%2F%2Fwww.jaguarforums.com%2Fforum%2Fxk8-xkr-17%2Fhelp-overheating-after-coolant-reservoir-replacement-137120%2F&v=1&out=http%3A%2F%2Fcimg6.ibsrv.net%2Fgimg%2Fwww.jaguarforums.com-vbulletin%2F1052x592%2F80-radiator_bottom_hose_popped_c63a9447d464fb8ab2e138b4a6985ec961dbed7b.jpg&ref=http%3A%2F%2Fwww.jaguarforums.com%2Fforum%2Fxk8-xkr-17%2F&title=HELP!%20Overheating%20after%20Coolant%20Reservoir%20replacement%20-%20Jaguar%20Forums%20-%20Jaguar%20Enthusiasts%20Forum&txt=This%20image%20has%20been%20resized.%20Click%20this%20bar%20to%20view%20the%20full%20image.%20The%20original%20image%20is%20sized%201052x592.)
There are a lot of posts on cooling system failures this time of year probably due to the stress of very cold weather and very old plastic parts.
In a month the posts will be about failed fuel pumps due to storage over the winter.
All hoses
Thermostat
Water pump
Love this picture!
I had this issue with two of my cars this winter. Both with new hoses and clamps. The huge temp swings here in Cincy they would leak for a moment. The times they did it the clamps were not tight enough. I am using the run of the mill screw clamps. Well one car is sold so good luck to them. The jag was the other one. I got them tight now with now leaks. I am thinking of getting the orig type for the jag.
This should be a metal part too IMHO. Bakelite will crack given the heat and stress.
Pristine97XK8Convertible
04-28-2017 11:08 AM
Camnelson324
09-27-2015 08:48 AM
