Upper shock mounts?
Received 4,282 Likes
Stu - 2 ways to check for certain if there is sag - measure distance between wheel center cap and bottom of fender - should be about 15.5 inches.
Second is to pop the bonnet and look at where the shock protrudes through the upper shock mount for reddish/brown flakes/debris as this is a sure sign the upper mounts have gone south. You may also see the shock shifted from center as once the foam pancakes, the shock may move within the mount
StuG (08-27-2016)
The following 2 users liked this post by Tracy Weiland:
mrrodger246 (08-28-2016),
StuG (08-27-2016)
+1 on checking the upper mounts. It's the usual culprit.
Center of hub to bottom lip on fender should be 15.75". At 15.25" or 15" it is likely the shock mount going bad. It can account for up to 3/4" of height.
Less than 15" and you might start thinking coils springs as well.
Check the various bushings while you're at it, although they have less effect on ride height. Some forum members report the bottom shock bushing as being a contributor to lower front ends.
StuG (08-27-2016)
Thank you all for the quick replies. Center of hub to bottom lip of fender measures 15.0" and upon examination there is reddish brown dust and cracking of the foam at the top of the mount.
I've ordered a new pair of mounts and that will be my next project upon their arrival.
Thanks again,
Stu
Thanks again,
Stu
StuG (08-28-2016)
LedZepplin
01-25-2017 04:37 AM
dsnyder586
03-30-2016 09:47 AM
