Upstream O2 connector
The following 3 users liked this post by motorcarman:
Thanks!
What about this Denso unit? It costs substantially less.
https://www.rockauto.com/en/moreinfo.php?pk=1607546&cc=1425844
Also, is it safe to only replace the one that’s throwing a trouble code or should both be replaced?
Received 1,701 Likes
Thanks!
https://www.rockauto.com/en/moreinfo...546&cc=1425844
Z
zray, normally I would agree with you, but I’m currently preparing to buy everything I need to rebuild the front suspension. Replacing both of those sensors would postpone the front suspension a few months.
20-30k miles could easily be 5 years from now with how often I drive it.
O2 sensors are HEAVILY monitored, so feel free to replace only the ones that fail. It is not really a "while you are there" situation. Replacing 2 sensors is just twice the work, and twice the $. Denso is fine.
Be triple sure you are ordering the right part. The upstream sensors are wideband, the downstream are narrowband. They work completely differently and are definitely not interchangeable. I had good luck removing my upstream sensor with a crowsfoot tool from the top.
O2 Tool
Best of luck, keep us posted.
O2 Tool
giandanielxk8 (09-13-2018)
O2 Tool
O2 Tool
Just to confirm, I want the tool to be ⅜ inch socket?
car5car
08-12-2019 06:33 PM
Red October
02-09-2015 06:32 AM
