urgent windshield help needed
I have a problem with my windshield installer and am in dire need of specific help that I can’t find in the searches I have performed. I will go into detail about the history of this problem once I get it resolved and post that wretched tale. Briefly, Bought car 2 hours away with a new windshield since it was cracked. Mirror fell off when I picked it up, assured it would be fixed. My local Jag dealership said wrong windshield was installed. I have auto headlights, auto dimming and rain sensors but windshield did not. After lots of hassle(have not been able to register it in my town yet because of this) the seller agreed to replace windshield correctly. Now heres the problem, I don’t think they are doing it right and I could really use documentation of some sort from Jaguar but I can find nothing. New windshield installed but mirror just fell off after 12 hours. I do not have a PC so I can’t download the service program but will certainly be purchasing the manual. Here are the questions I need answered:
1-the windshield came with the black area which included a circle for rain sensor but nothing mounted to the glass in that area. There is the metal tab above that area. Is this right or is there supposed to be something mounted on glass for the sensor to seat to?
2- he said the metal tab serves no purpose on my car, is that right? Sounds absurd.
He will not believe me unless I show him specifically how Jaguar intended it to be done, service manual pages would be helpful. That’s why it is so urgent. Please help-this has been a month of my life and they have me by the kahonas. Thanks
2002 Jaguar XK8- build date of May 2002
The JTIS windshield replacement procedure is too big a doc to upload to the forum. Here's a link to it on my MediaFire account:
JTIS - 2002 Windshield 76 81 40.pdf
Have you the Coupe or the Convertible? There's a few different part numbers depending on body style and spec.
Check this thread for photos:
https://www.jaguarforums.com/forum/x...ar+view+mirror
Cant really help you but can relate. I needed a new windshield, gave the vin and everything and the company still tried to install the wrong windshield. I told them before the set it on the car is wasnt correct but they still tried to put it in anyway. Thank god they didnt final set it, once they noticed the rain sensor and how the mirror wouldnt fit they realized they needed to order a different one. Someone will get it worked out for ya im sure, I know the correct windshield was $50.00 more than I was quoted and the company had to eat it since it wasnt me fault they didnt order the right one the first time.
Check out this thread:
https://www.jaguarforums.com/forum/x...51/#post480482
There are a couple of good photos that may be of use to you.
Mark
Mark
XK8 & XKR 4.0 ltr Convertible - Windcreen.pdf
10 different part numbers covering the options of heated / non-heated / no rain sensor / circular rain sensor / triangular rain sensor.
Aftermarket or Jaguar windshield both are the same for the mirror connection the problem with the mirror falling is not uncommon. I had 3 windshields installed in my car (all aftermarket) and they were just fine, the mirror needed adjusting. See if my link helps JagRepair.com - Jaguar Repair Information Resource When you make adjustments to the bracket use caution it can and will snap in two if you apply excessive pressure. I hope this helps.
Do NOT sand the glass or 'foot/bracket'. The correct adhesive is anaerobic and depends on absolutely smooth surfaces in order to cure.
I think I have this solved, after going to another glass installer. It took a couple of try's but I was able to look at the correct glass and it all makes sense. It looks like the first windshield they put in was a plain sensor less window. In order to get it to work with the mirror they had to chisel the mount off the old glass and try to glue it to the new windshield.(fail) The second incorrect windshield had the rain sensor but not the auto lights. (fail 2) Both of these have a different mirror mounting tab than the correct one which has a mounting tab that encompasses the rain sensor and has an area for the light sensor. I think I trust the factory mounted bracket more than their autozone glued bracket.
Thanks for your help in resolving this - threes a charm!
Charlene n John
09-28-2015 06:01 AM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
innzane
09-02-2015 10:08 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
